Morning all,
After much researching I have decided on a new set of BFG AT tyres for my 110 csw. Dilema now.... Do I stick with 235/85 x16 or go to 265/75 x16 ? (negligable height difference between the two sizes).
My thinking is 235... standard size so IF I had to replace one anywhere outside UK, it should be relatively easy. Being standard, theoretically, there should be less strain on drive train components.
My thoughts for 265/75...slightly wider track, theoretically, the Landy should be more stable, bigger footprint (not always advisable I know), better / more comfortable on sealed roads (less sidewall to flex).
What do you all run?
All input greatly appreciated
tony
