| | Terracan TLC | |
| Subject: Terracan TLC Fri Mar 25, 2011 8:19 am | |
| Basicaly over the past 2 winters with all the road salt and grit, muck and dirt my rear axle and a fue surrounding components were starting to look abit tarnished, orange, a fue "flakey" bits. Im not much of a fan of this so I decided to do something about it. Local companys quoted £70 for the rear half of my vehicle to be sprayed. I cleaned the rear underside of my vehicle, used a wire brush on the fue patches that looked flakey and the brushed off the last of the bits. I bought a 500ml of Hammerite smooth black and a paint brush for £12.99 and set out to paint the rear axle, panhard rod, anti-roll bar and a fue other metal components of the rear section of the vehicle for the next 3 hours. I applyed 2x coats of paint and im fairly happy with the result. Before: After: Hopefully this will help the axle, chassis and other components against road salt&grit and off road mess. I will be doing the front IFS next with the SuperPro bushes so ill post pics when done. TJ | |
| Subject: Re: Terracan TLC Fri Mar 25, 2011 1:20 pm | |
| Somebody's knicked your ladder chassis! | |
| | | chally2 Just got M&S Tyres
Posts : 140 Join date : 2011-02-02 Age : 43 Location : berkshire
| Subject: Re: Terracan TLC Fri Mar 25, 2011 7:16 pm | |
- Somebody's knicked your ladder chassis!
Ha Ha I waxoyl mine every year I bought a cheap compressor from costco for £100. Worth the investment if your going to do it more than once good job wth a brush though | |
| Subject: Re: Terracan TLC Fri Mar 25, 2011 8:51 pm | |
| you should have found a good pressure washer and blasted it first that way it takes a lot of loose bits off and gets where you cant with a wire brush,,,,then do what you did,,,but what you have done will help combat the effects of winter,,,,, | |
| Subject: Re: Terracan TLC Fri Mar 25, 2011 10:40 pm | |
| Ta, all. The chassis is still there, im pritty sure. It would be better to get a compressor and spray it on like you mentioned but this was basicaly a test to see if i could treat the concerned areas for less than £20. I will probably get the whole underside done next year, but for the moment in time its not really needed as the vehicle is only 7 yrs old. Its still good to know that you can still do something on a budget. Jas | |
| Subject: Re: Terracan TLC Fri Mar 25, 2011 10:42 pm | |
| - tuggy wrote:
- you should have found a good pressure washer and blasted it first that way it takes a lot of loose bits off and gets where you cant with a wire brush,,,,then do what you did,,,but what you have done will help combat the effects of winter,,,,,
EDIT: Typo, when I cleaned the underside i did use a pressure washer, works well. The amount of muck and dirt.......... | |
| Subject: Re: Terracan TLC | |
| | | | Terracan TLC | |
