 Towing/recovery strop advice
3 posters
Andy_C
Towing/recovery strop advice Empty
PostSubject: Towing/recovery strop advice   Towing/recovery strop advice EmptySat Nov 30, 2013 9:26 pm
Hi all, as a newcomer to off-road travel I'd like a bit of advice on selection of a towing strop and shackles. We have a Merc 814DA, running weight around 6.5 tonnes. What length/capacity towing/recovery strop should I be looking at, and what type/capacity of shackles? It already has a 13000kg winch fitted.
We don't expect to be doing a lot of serious off road stuff but would like to be prepared 'just in case'!
Thanks Smile
Andy
PostSubject: Re: Towing/recovery strop advice   Towing/recovery strop advice EmptySun Dec 01, 2013 1:59 pm
Anything rated over 13,000Kg.
Length, depends upon what use you put it to, but I find a 7M strop is fine as it can be folded in half to give a 3.5M length, and a 4M one also.
PostSubject: Re: Towing/recovery strop advice   Towing/recovery strop advice EmptyMon Dec 02, 2013 1:20 pm
You won't get better advice than from Alan Satchell at www.liftingandcrane.co.uk Alan is an avid off-roader himself, so can point you in exactly the right direction for your needs. By all means say Tom McGuigan recommended him.
» Champion winches + Other winches
» Crazy Off Road Expedition/Overland Towing
» Unusual recovery technique
» Underrated, often overlooked recovery tool
» Possible overkill
4x4 Overland Travel :: Vehicle recovery-
