 satmap active 10
PostSubject: satmap active 10   Sun Feb 20, 2011 6:36 am
I was just wondering if anyone has used this. Is it any good. It is a little expensive.
But can it be used abroad and does it give you a grid reference for use with a map.
landy andy
PostSubject: Re: satmap active 10   Sun Feb 20, 2011 6:44 pm
I looked at one when I went to buy my Memory Map 3500 GPS, and thought it was ok.
BUT did not come with map program so that you could plot route at home before you hand. I also found the MM easier to use.
I run a computer in my truck and wanted the up to date maps, so brought the MM 3500, as it comes with all the latest maps, and then makes the GPS unit almost free.
Go to a few shops and physically play with them, people (on here and in the shops) will be biased due to what they have or like (me included), so go and play.
satmap active 10
» First Timer
» Homemade Compost Activator
4x4 Overland Travel :: Navigation-
