 Engel Fridge Freezer
Go to page : Previous  1, 2
PostSubject: Re: Engel Fridge Freezer   Wed Feb 09, 2011 10:00 pm
We got are engal second hand, came with coverso just left it on, clinking teacups
Vixen
PostSubject: Re: Engel Fridge Freezer   Thu Feb 10, 2011 2:45 pm
4x4overlander wrote:
We use insulated jackets on both our Engel and ARB fridges.
Covers are rather dirty and have taken some punishment from putting items in and out of vehicles. What the actual thermal insulation is I do not know.
Helps keep fridge in decent condition.
Wot he said....my Engel lives in it's cover also. Certainly protects it from knocks and scrapes.
tacr2man
PostSubject: Re: Engel Fridge Freezer   Tue Feb 15, 2011 10:53 pm
The insulated cover for the engel helps reduce the duty cycle in high ambients , I had a small engel , but when I changed I went to a Supakool (Aussie made fridge) as it out performed the engel , it has twin motors and fan forced cooling interior.
I have heard good things about waeco and National Luna , so its not quite the one horse race it once was, especially when you look at engel prices . JMHO
PostSubject: Re: Engel Fridge Freezer   Wed Feb 16, 2011 12:08 am
The cheapest price for an Engel MT45 is about £655 whereas the ARB fridge is about £735 so the Engel has the edge over the Engel on price.
But are you comparing like with like?
ARB fridge lid stays on. Costs £6 to stop the Engel lid sliding off
ARB battery safe guard buit in. Cost £52 extra for the Engel battery monitor
ARB temperature display inbuilt. Costs an extra £24 for the Engel temperature monitor. Yes this is a remote one
Now the price difference has disappeared
Internal volume?
ARB 47 litre, Engel 40 litre
We have both fridges in our vehicles and know which one we prefer. Also we have battery monitors on the split charging systems as well
PostSubject: Re: Engel Fridge Freezer   Wed Feb 16, 2011 12:42 am
Interesting comparison. So apart from the price difference, no negatives for the ARB compared to the Engel then?
PostSubject: Re: Engel Fridge Freezer   Wed Feb 16, 2011 12:57 am
So far none that we have come across.
There are some other clever design features in the ARB such as curved interior corners which makes cleaning it easier and the drain plug.
The ARB fridge does not look as tough as the Engel but it is. It has powder coated steel sides which gives it the impression that it is made from plastic but that is not the case.
One person expressed concern about the front latch and thought it would break. However we have been using one for about a year and the last 5 months it has been used daily down at the lock up and at home with no problems.
Have not 'played' with the other ARB fridges in their range but would expect them to be of the same standard.
I do not have personal experience of either the Waeco or National Luna fridges
kevinf
PostSubject: fridge wars   Sun Feb 27, 2011 1:05 am
my vote goes to engel
had one for 3 years now spends all the time its not in the back of the landie as a counter top freezer in the kitchen,when its in the vehicle the power consumption is minimul,its also been to center parc's one christmas and it payed for its self with the amount of money we've saved being able to carry food with us and not rely on over priced camp/holiday centre shops
Vixen
PostSubject: Re: Engel Fridge Freezer   Mon Feb 28, 2011 11:45 am
Waeco fridges had a problem with the lids warping and not sealing properly. Not sure if that issue has been fixed.
My Engel has a digital temp display on it. Not sure if they all do, but I know ones made before my model did not. Out of interest, I have not had any problems with the lid falling off. The cover velcros to the lid and that tends to keep it in place. It does occassionally slide over slightly, but has never been a problem. Very Happy
Vixen
PostSubject: Re: Engel Fridge Freezer   Mon Feb 28, 2011 11:48 am
Brendan, the Engel has also got curved interior corners...or at least mine does Wink
PostSubject: Re: Engel Fridge Freezer   Mon Feb 28, 2011 2:11 pm
Just spent last week getting stuff in and out of a Waeco.
Not impressed with catches or slid sliding on hinges.
OK not a scientific test but I personally would rank ARB 1, Engel 2 and Waeco 3 with National Luna being an unknown quantity to myself.
Standard ARB in UK costs more then standard Engel but buy the add on's to Engel so you have the sme spec/type of fridge there is little in it on price.
horacebat
PostSubject: My Engel!   Tue Mar 01, 2011 12:41 am
Well .. I've had a couple of weeks of living with my engel and it must be said is the beeze knees!. It's not the quietest in the world, and some may say its a bit industrial! (mines a second hand one, with none of the niceties!), but all in all, its pretty good!
PostSubject: Re: Engel Fridge Freezer   Sun Apr 10, 2011 12:31 am
Another vote Engel. Especially if you get the Two zone for it.
Six months none stop use.......The Numax battery stood up well. 36 hours at 36 deg C ambiant before the Engel battery moniter cut it off.
PostSubject: Re: Engel Fridge Freezer   Sun Apr 10, 2011 2:13 am
ARB Fridge costs £737
47 Litre Fridge Freezer Specifications
Capacity:
47 litres (72 x 375ml cans)
External Dimensions: H508mm x W380mm x D705mm
Internal Dimensions:
Fruit & dairy compartment: H206mm x W285mm x D151mm
Main compartment: H401mm x W285mm x D337mm
Weight: 22.5kg
Cooling Capacity: +10°C to -18°C
Power: Built-in 12/24V DC and 100-240V AC power
Integrated battery protection system
Current Draw: 0.87 amps/hour*
*Power consumption tested at 3°C cabinet temperature, 26°C-31°C ambient temperature range, test duration of 66 hours and supply voltage of 12V DC
Engel Fridge Costs £692.59
FEATURES:
100% CFC Free Automatic Voltage Selection AC / DC Right Angle DC / AC Leads
Thermostat Controlled Generator & Solar Panel Compatible Turbo Fan
Energy Efficient Sawafuji Swing Motor Strong Construction Carry Handles
Low DC Current Draw: 12V 2.5 Amps Compact & Lightweight Stainless Steel Door Latch
Digital Temperature Guage Noise Level: 32dB 3 Year Manufacturers Warranty
Silver Metallic Finish Polyurethane Insulation
SPECIFICATIONS:
Litres 40 Litres (60 x 375mm Cans)
H x W x D 508mm x 631mm x 360mm
H x W x D 370mm x 380mm x 260mm
So Engel fridge is apparently cheaper then the ARB. Buy the Engel battery monitor at £52.14, so in fact the Engel is actually smaller and more expensive then the ARB.
YES, we do have both an Engel and an ARB fridge in use in our vehicles
Yes we have intelligent slit charging systems in both our vehicles. The IBS systems have a continuous display of both battery voltages whereas the Gensis system works slightly different and whereas the battery voltages can be displayed they are not displayed continuously.
Currently all our Land Rovers run on Odyssey batteries which are combined starter/leisure batteries
PostSubject: Re: Engel Fridge Freezer   Sun Apr 10, 2011 12:42 pm
Brended
Will you please explain to me how these "intelligent" charge systems work that keep your battery charged ALL the time ?
Most I've seen are a set of fairy lights with a relay inside the box.
I still don't understand how they work when the engine isn't working ??
PostSubject: Re: Engel Fridge Freezer   Sun Apr 10, 2011 3:08 pm
Well since it is obvious that question is not aimed at me, I will not bother even trying to answer it!
PostSubject: Re: Engel Fridge Freezer   Mon Apr 11, 2011 7:38 pm
Yes we have intelligent slit charging systems in both our vehicles. Brendan
What's this? On second thought, don't answer!!! affraid
PostSubject: Re: Engel Fridge Freezer   Tue Apr 12, 2011 1:26 am
Trust YOU to notice that typo!
Now how do I answer that?
Oooops sorry I can't this is a family friendly forum Razz
landy andy
PostSubject: Re: Engel Fridge Freezer   Wed Apr 13, 2011 1:11 am
PostSubject: Re: Engel Fridge Freezer   Wed Apr 13, 2011 5:39 am
Innocent little me, perish the thought? Must be your mind Bedlam ... opps, another darn typo! Razz
trs5
PostSubject: I have an Engel for sale if you are still looking.    Mon Feb 06, 2012 4:02 pm
horacebat wrote:
I'm on the lookout for an Engel. If you know of any "Good Value" Second hand ones, please let me know.
Many thanks
PB.
It's a 60L comes with both leads, 2 baskets and 2 handles.
Page 2 of 2Go to page : Previous  1, 2
» Engel Fridge Freezer
» dometic fridge / freezer
» Dometic RM7650 L fridge / freezer SOLD
» Need for second fridge or freezer?
» Engel mt 45 top freezer
4x4 Overland Travel :: WANTED: Private advertisements only-
