 Terracan - Induction noise?
3 posters
TEH KICK INSIDE
Terracan - Induction noise? Empty
PostSubject: Terracan - Induction noise?   Terracan - Induction noise? EmptyWed May 17, 2017 11:52 pm
Hi Guys, newby here and with a question ....
2006 Terracan 2.9 CRDI Auto 65k miles....
Just bought it and had it serviced (cam belt, new water pump and filters etc)
Noticing a sound under engine load - somewhere around either a rubbing or sucking sound, constant when you hear it, doesn't change with speed or engine revs (possible gets slightly louder with more revs)
Only occurs under load (re the engine on the drive as much as you like no noise)
Tickover no Nosie
engine under minimal load at steady speed no noise
descending hill at same speed and engine revs - using engine breaking - no noise
accelerate - noise...
Left off - noise stops
almost like its when the turbo is boosting?
seems to be from front right of vehicle and doesn't get louder if you open the window.....
Garage are not getting anywhere...
Is audible induction noise normal?
thanks in advance
PostSubject: Re: Terracan - Induction noise?   Terracan - Induction noise? EmptyThu May 18, 2017 5:06 am
Never had a Terracan but have had a few vehicles with turbos and with most you will hear a bit of whistling sound under acceleration. If that is what it is, just make sure the air intake isn't letting in unfiltered air that could damage the Turbo or engine.
I know there are a couple of people on here who have had Terracans who might be able to help more.
TEH KICK INSIDE
PostSubject: Re: Terracan - Induction noise?   Terracan - Induction noise? EmptyThu May 18, 2017 5:11 am
Thanks,
Had quite a few turbos myself both petrol and service, ncluding lifted l400's and turbo bricks, this isn't awhistle like turbo spooling but it could be a sucky inlet resonance type noise
Garage have had a look today and can't find anything ....
PostSubject: Re: Terracan - Induction noise?   Terracan - Induction noise? EmptyThu May 18, 2017 9:05 pm
Again never had a Terracan but could it be the hoses's delamination, just a quess, clinking teacups
» Terracan Storage - (Now Terracan Re-Design)
» Terracan Key Fob
» Terracan egr
» Terracan BHP
» Terracan Intercooler Fan
