| 12V THERMOSTATIC NIGHT HEATER | |
tuggy Just Got Spot Lights
| Subject: 12V THERMOSTATIC NIGHT HEATER Tue Nov 19, 2013 7:32 am | |
| Ok i have bought a 12v night heater from airstream so i will do the blog of the fitting in and testing.... ok it arrived today..parcel soaked in diesel,, ,,,took it to the garage and opened it up the filler cap on the tank had come off and in transit the little bit of diesel in the tank went everywhere,,,,,, so not amused,,,,no instructions so i had to go on the web site and down load a right load of gobbledegook... ...not amused again.... so in the end i phoned the guy up and fair play he talked me through it...anyway got it running its not bad chucks out some good heat but a bit smoky when it shuts down ...ordered the heater hose ducting and the vent as it dosnt come with it thats another £34 and ordered the aluminium box for under the truck that was another 215 quid.... ok when that lot arrives i can put it all together..... ok will post some pics tomorrow and a vid...... | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Tue Nov 19, 2013 10:41 pm | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Wed Nov 20, 2013 6:36 am | |
| Strewth, it's ginormous! Just in case it all get too much for you, I just looked up at www.airstreamheaters.co.uk and it states, "We now provide a 'Supply & Fitting Service". Here to help. | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Sat Nov 30, 2013 3:05 am | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Sun Dec 01, 2013 2:03 pm | |
| Bloody hell Tuggy, what are you running? a sauna. | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Sun Dec 01, 2013 2:05 pm | |
Posts : 1392 Join date : 2010-12-26 Age : 76 Location : Nearly thier
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Tue Dec 03, 2013 8:53 am | |
| Well we used the candles floating in water in the camper. | |
Peej Just Bought 4x4
Posts : 76 Join date : 2013-10-24 Age : 67 Location : Scottish Borders
| Subject: 12V THERMOSTATIC NIGHT HEATER Tue Dec 03, 2013 6:51 pm | |
| Hells Teeth Tuggy, That's straight off the drawing board of Frank Whittle! | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Tue Dec 03, 2013 9:49 pm | |
| - Peej wrote:
- Hells Teeth Tuggy, That's straight off the drawing board of Frank Whittle!
Better Whittel than Brunel in this day and age. But I was thinking more Flash Gorden | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Fri Feb 21, 2014 2:51 am | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Fri Feb 21, 2014 3:09 am | |
| Very neat job, waiting for the last post when all up and running, we have a diesel heater in our new motor home, we have a diesel heater in our motor home, a little bit smaller than yours, | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Fri Feb 21, 2014 9:14 am | |
| Two diesel heaters in your new motor home Yoda? Blimey Tuggy, that box seems very low - below the spring-hangers in fact. Won't that compromise the ground clearance? | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Sun Feb 23, 2014 1:42 am | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Tue Feb 25, 2014 8:38 am | |
| ok got a new battery today and wired up the unit..... ......did its first test run up in the box and everything went very well it came up to temp very quickly i let it run for about 20-25 mins and nothing caught fire.. .. so thats a good sign. ..had to drill thirty little holes to let air into the inlet i didnt want to put big holes incase muck got in......switched it off and let the cooling cycle run its corse and everything was fine..still have to tidy the wiring up and relocate the switch inside the cab ..and nice and warm inside.....maybe to warm... .. | |
| Subject: 12V THERMOSTATIC NIGHT HEATER Tue Feb 25, 2014 1:34 pm | |
| Nice installation and congratulations Tuggy, from a diy point of view how easy on a scale of 1 to 10? 10 needing a fully equipped machine shop. | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Tue Feb 25, 2014 10:12 pm | |
| - Peej wrote:
- Nice installation and congratulations Tuggy, from a diy point of view how easy on a scale of 1 to 10? 10 needing a fully equipped machine shop.
easy if you are handy at DIY [destroy it yourself] about 3-4 on your scale.... | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Wed Feb 26, 2014 4:35 am | |
| I concur, a very neat installation. Not for a second did I really think it would compromise the ground clearance (just playing Devil's advocate), you're too long in the tooth to make such a basic mistake. Besides, I know your thoughts on 4x4s ... they're for using, not posing!
Will have to see it in the flesh of course, you were the guinea pig after all, then if all's well I will have to invest in one for the RR ambulance camper. Must stop calling in an ambulance! For the price it has to be the most cost-effective option around? | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Thu Feb 27, 2014 4:41 am | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Thu Feb 27, 2014 4:47 am | |
| Good thinking Batman! | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Thu Feb 27, 2014 4:51 am | |
| Boasting again Tuggy, "I've got 13 inches eh" Seriously it's looking really good top job | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER Wed Mar 05, 2014 9:19 pm | |
| ok had some time on the truck yesterday...I finished putting the new wiring in and rewired the interior lights also had a spare T MAX compressor so bolted that in the belly box and wired that in so i now have onboard air i might fit a small compressor tank in but thats more space i have to find and more weight.. .so might just stick with a long air line... i moved the heater switch and mounted it under the seat locker so thats job done and it works very well. then i built the box around the header tank so thats all safe now.. ...next job is to do the cab insulation keep watching this space... . | |
| Subject: Re: 12V THERMOSTATIC NIGHT HEATER | |
